Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Envoy
Engine
Crankshaft
Vacuum
2005 GMC ENVOY
150,000 MILES • V8 • 4WD • AUTOMATIC
RNDYMN
MEMBER
1 POST
Can a vacuum problem cause 4wd not to engage and ignition not to function some times ( crank shaft position )
Jan 31, 2016 at 5:16 AM
CATAFINA
Experienced Mechanic
If its not starting up could be the crankshaft position sensor, for the vacuum I doubt it on the 4WD
Jan 31, 2016 at 6:51 AM
HMAC300
make sure your anit theft isn't engaged for no start. if no manual look online
Jan 31, 2016 at 11:07 PM
Add image or video
Ask a new question
Check engine light
Engine stalls while driving
