Replaced the A/C compressor and recharged A/C and still blowing hot air?
97,780 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
TRUCKERLANCE
  • 5 POSTS
Cooling fan comes on and off. While getting my oil changed at local Ford the tech showed me that my vacuum pump was leaking oil. Brakes are good A/C not. Should I just go and replace the pump or just the seals? The A/C is holding refrigerant. Can the vacuum pump cause A/C to blow warm.
Aug 20, 2023 at 3:34 AM
  • 55,782 POSTS
vacuum pump? Do you mean the compressor? We should get a set of pressure gauges on the system to see if the seals are bad inside the compressor. Please go over this video and guide:
https://youtu.be/4EqdrBVb0sY?si=mJxyc2pJM_acueHn
and
If the pressure is about the same form high to low side the compressor is bad. Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Aug 21, 2023 at 3:10 AM
TRUCKERLANCE
  • 5 POSTS
The seals. Meant to say gaskets for vacuum pump. The compressor is brand new, not refurbished or remanufactured. The compressor has oil in it and no leaks. The vacuum pump has an oil leak. Fan clutch is good and checked fuse box of both sides under hood driver side.
The HVAC control works when selecting lo to hi, etc.
Aug 22, 2023 at 3:06 AM
  • 55,782 POSTS
Can I ask what problem are you having? Please be detailed.
Aug 24, 2023 at 3:08 AM
TRUCKERLANCE
  • 5 POSTS
Replaced compressor with new one. Recharge system and still blowing hot through vents. Can hear the click on and off. I do have a bad vacuum pump casket leaking oil but not bad. Defrost works. May have an A/C line leak now cause it's not holding coolant. I'm about to say no more with Fords because it's just a stupid design and a long list of problems with this car that is at 98000 showing its ugly face.
Sync system is a joke.
BTW
I owned Mustangs and F150s, Focus and Fusion and what a bit.
Aug 24, 2023 at 3:04 PM
  • 55,782 POSTS
It sounds like you found the problem with the system leak.
This guide can help pinpoint the leak:
https://www.2carpros.com/articles/air-conditioner-leak-detection
Please go over this guide and get back to us.
Aug 25, 2023 at 4:57 AM
