A/C vacuum and charge
123,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
DADDYA
  • 29 POSTS
I charged my A/C system and it leaked out over night. I put UV dye in the system and found it was the low pressure side Schrader valve. I put a new valve in so do I need to vacuum the system again or just put refrigerant in?
Aug 5, 2017 at 9:15 AM
CJ MEDEVAC
  • 11,000 POSTS
Yes,
I would vacuum it again, at least for thirty minutes.
Better to do it right the first time, or you might get to do it a second time.
The Medic
Aug 5, 2017 at 10:51 AM
DADDYA
  • 29 POSTS
Thank you Medevac it was my first time messing with an A/C system but thanks to 2carpros I really appreciate it guys.
Aug 5, 2017 at 8:36 PM
CJ MEDEVAC
  • 11,000 POSTS
Just here to give some help.
Let us know how cool you are riding around when you get it all done.
Soon as I get my new water pump on 'Willy' (below) I will be pretty cool once again also! (Wife has been in the hospital for three weeks with exhaust issues. time has not been easy to find).
The Medic
Aug 5, 2017 at 11:34 PM
DADDYA
  • 29 POSTS
I forgot to ask do pag46 have to be added to the system again?
Aug 6, 2017 at 12:17 AM
CJ MEDEVAC
  • 11,000 POSTS
Did you bleed it down slow?
Did you lose much?
The Medic
Aug 6, 2017 at 1:02 AM
DADDYA
  • 29 POSTS
It leaked out over night the compressor would not kick in. Will I have to get the oil/dye injector or is there another way to add PAG46?
Aug 6, 2017 at 2:19 AM
CJ MEDEVAC
  • 11,000 POSTS
If there was not evidence of oil leakage, gas it back up.
The oil that you already installed is distributed throughout the system.
The Medic
Aug 6, 2017 at 2:33 AM
DADDYA
  • 29 POSTS
Thank you Medevac your help is greatly appreciated plus that is a cool Willy's Jeep.
Aug 6, 2017 at 2:50 AM
CJ MEDEVAC
  • 11,000 POSTS
Never have problems with the Willy;s A/C.
Picture below, it is on "Max"
Let us know how yours is working out, may the force be with you!
The Medic
Aug 6, 2017 at 2:57 AM
