using water
180,000 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
MIKE1127
I have 02 sentra ser uses water sometimes and somtimes knot no water in oil dont overheat cant find a leaking hose what else could it be
Dec 27, 2015 at 11:56 PM
CARADIODOC
  • 34,414 POSTS
Best suspect is a leaking cylinder head gasket. One test is to add a small bottle of dark purple dye to the coolant, then check a day later with a black light. The dye will show up as a bright yellow stain that you can follow back to the source. If a head gasket is leaking, you'll find the dye inside the tail pipe.
Dec 28, 2015 at 12:39 AM
