Using too much fuel
2003 OLDSMOBILE ALERO
177,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
JCTEXWEB1
  • 12 POSTS
Car misses bogs down, there is black smoke coming out the muffler, soot on plugs and muffler and it uses a lot of fuel.
Aug 7, 2016 at 12:39 PM
RIVERMIKERAT
  • 6,110 POSTS
Have it scanned for both hard and soft codes. Replace the plugs. Check the plug wires.
Aug 8, 2016 at 12:08 AM
JCTEXWEB1
  • 12 POSTS
8/8/16 we are having it scanned tomorrow the auto parts scanner does not seem to read enough into the cars symptoms
Aug 8, 2016 at 2:36 PM
  • 55,433 POSTS
Has the engine been tuned up recently? Also I would check for a blown fuel pressure regulator.
Here is a guide for you.
Let us know what you find so it can help others.
Best, Ken
Aug 12, 2016 at 2:39 AM
JCTEXWEB1
  • 12 POSTS
August 13
Car is being used for work fuel pressure regulator not leaking fuel when vacuum line disconnected. Am suspecting maybe a injector wire shorting or the vacuum modulator valve because i neglected to mention that 2nd gear does shift hard. Will keep considering all your suggestions thanks to all and i will be back to confer.
Aug 13, 2016 at 1:44 PM
  • 55,433 POSTS
Here is a guide to check the injectors
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Please let us know what happens
Best, Ken
Aug 15, 2016 at 4:53 AM
JCTEXWEB1
  • 12 POSTS
Okay
Aug 15, 2016 at 5:42 AM
JCTEXWEB1
  • 12 POSTS
Car is showing these codes:
P0112 p1171 p0340
Aug 17, 2016 at 11:56 PM
JCTEXWEB1
  • 12 POSTS
P0112 p1171 p0340
P1171 - Fuel system lean during acceleration
P0340 - Camshaft Position Sensor A Circuit (Bank 1 or single sensor)
P0112 - Intake Air Temperature [IAT] Sensor Circuit Low Voltage
Aug 18, 2016 at 1:20 AM
  • 55,433 POSTS
The cam code makes me think the engine has jumped time. Do a compression test and if low check the timing chain. here is a guide and diagram so you can check it out.
Please let me know what you find
Best, Ken
Aug 18, 2016 at 4:13 AM
JCTEXWEB1
  • 12 POSTS
Okay will check thanks
Aug 18, 2016 at 4:49 AM
JCTEXWEB1
  • 12 POSTS
Have not done compression test yet we got it scanned with a bigger scanner same codes show up so we inspected boots for spark plugs and thet were bad losing spark got them replaced still missing there is a sound coming from manifold thats souns like a light knocking suspecting a valve or a torn gasket.
Aug 20, 2016 at 7:50 AM
  • 55,433 POSTS
Please do a compression test to see if one of the cylinders is low on compression which would mean you have a leaking intake valve.
Please let us know what you find so it will help others.
Best, Ken
Aug 21, 2016 at 1:57 AM
JCTEXWEB1
  • 12 POSTS
Spark plug boots were arcing we changed them but still have original problem i neglected to mention a sound its making and it sounds like a valve. Metal on metal dry tapping. Have not done compression test yet, thats next.
Aug 30, 2016 at 1:08 AM
RENEE L
  • 1,260 POSTS
Have you done a compression test yet?
Aug 30, 2016 at 2:09 AM
JCTEXWEB1
  • 12 POSTS
Okay now car stopped running completely so it probably will be easier to check
Sep 29, 2016 at 11:14 PM
  • 55,433 POSTS
Here is a guide that will help, please get back to us
Best, Ken
Sep 30, 2016 at 4:05 AM
JCTEXWEB1
  • 12 POSTS
Car still not running no money to fix it
Oct 29, 2016 at 1:35 AM
  • 55,433 POSTS
Let us know what happens we want to help you get it running.
Oct 30, 2016 at 1:13 PM
JCTEXWEB1
  • 12 POSTS
Car finally broke down and my son just got rid of it. Thanks for all your time and effort it was appreciated.
Jan 9, 2017 at 12:22 PM
  • 55,433 POSTS
Sorry we could not get it fixed for you, please use 2Carpros anytime.
Jan 10, 2017 at 3:13 AM
