USING AN OBD2 SCANNER ON MY 1997 SATURN SL2
1997 SATURN SL2
176 MILES
JAMIEA
When the scanner is connected to the under-dash port in my Saturn, it doesn't even turn on. The connection appears to be fine, with compatible connectors on both car (under dash, driver's side), and the scanner. The ignition is in the on position. The scanner works fine in my other cars. But when it's connected in the Saturn, it remains off. No readout, no codes, no nothing. What can this possibly be??? Thank you.
Jun 5, 2013 at 2:44 PM
SATURNTECH9
  • 30,869 POSTS
See if the body fuse is blown in the inside fuse box?
Jun 5, 2013 at 3:02 PM
JAMIEA
To saturntech9:
Thank you so much for your response to my question of June 5th. You were absolutely correct about the problem being caused by a blown body fuse. I had no idea there was a body fuse! Problem solved; no codes came up on the scan, and all is right with my world. I love 2carpros.com. From jamiea.
Jun 6, 2013 at 3:35 PM
SATURNTECH9
  • 30,869 POSTS
Your welcome anytime thats what were here for glad to hear it was just a fuse.
Jun 6, 2013 at 3:48 PM
