I purchased both the PCM and BCM from the same vehicle, same year as mine. Do I need to get both programmed? I'm hoping this will solve my problem with the pass lock not allowing the ignition to start. I tried to get the original BCM to go into learning mode for a new ignition/key, but it just won't do it the security light just slowly flashes between security and battery. I'm looking for the least expensive solution, I've already put a good deal of money into this problem.
Oct 9, 2022 at 11:47 PM
