Used flex plate installation
219,000 MILES • 3.0L • 5 CYL • 2WD • AUTOMATIC
DUDLEYMARKS
Any ideas on what type of steel, tensile strength, tempering, elongation of original flexplates? I'm leery of installing a used plate if I can have one waterjet cut using the used plate as a pattern. Thanks!
Mar 14, 2019 at 11:45 PM
JOETECHPRO
  • 705 POSTS
Hey DUDLEYMARKS,
I can't say I have the information regarding the specifics of Flex-plate for that vehicle. Getting one custom made or finding a manufacturer of OE quality would be the way to go i would say. A used unit will always be a gamble but direct fit. You wouldn't want to run into meshing issue or balance problem that could cause engine/starter damage.
Contacting the transmission manufacturer would be an option (Looks like it is a Mercedes/Daimler AG manufactured transmission)
After a search i found two sites that might be worth contacting with these questions also.
www.amtechinternational.com - Manufacturers of OE spec Flexplates
http://www.atiracing.com - Manufacturer of aftermarket Flexplates
They might have your answers or be able to point you in the right direction.
Let me know how you get on.
Many thanks, Joe
Mar 17, 2019 at 5:59 AM
