It is possible that this sensor caused the issue but did they replace the sensor or just unplug it and reconnect the same one? If they did not replace it then I suspect they did not fix anything.
The Mass Air Flow sensor tells the PCM how much air is coming into the engine so that it knows how much fuel to add. If this is faulty then it will dump too much or not enough fuel and it will cause issues as you experienced. However, there are other things that can cause this as well.
If they did replace it, did you drive it again and see if it was repaired? If it were me, I would not buy the vehicle until this is repaired. At the very least, I would ask that they agree to repair this after you buy it no matter what it turns out to be. If they agree to that, get it in writing and have them be clear on what the issue is so they can't say that the issue is different.
Let me know if you have questions.
Aug 27, 2019 at 10:22 AM
