Where is the upstream O2 sensor located?
184,309 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
BILL JOHNSON4
I need to know exactly where the upstream O2 sensor is located on my vehicle listed above and a diagram if available?
Dec 25, 2023 at 7:31 AM
  • 110,248 POSTS
The upstream O2 sensor is at the rear of the engine and mounted on the exhaust manifold. I attached a pic below showing the location.
On this vehicle, there are two sensors, an upstream and a downstream. The downstream is after the catalytic converter and the upstream is before it.
take care,
See pic below.
Dec 25, 2023 at 2:03 PM
