I am having trouble locating the upper vavle body In relation to rest of the parts under hood.
Oct 7, 2014 at 2:34 AM
WRENCHTECH
✓Experienced Mechanic
Upper valve body? Are you working on an engine or a transmission?
Oct 7, 2014 at 4:00 AM
NADIFUBYNATURE
MEMBER
I believe it is the transmission but my primary goal is to replace a shift solenoid. I noticed a diagram you had posted about this. But I dont really know where to look under the hood
Oct 7, 2014 at 4:09 AM
WRENCHTECH
If you're fixing a transmission, you aren't going to find the parts under the hood. shift solenoids are internal to the transmission and unless you are very familiar with transmission work, don't think you should be attempting this yourself.
