upper timing chain gasket
208,996 MILES • 4.4L • V8 • RWD • AUTOMATIC
REARDRIVE
  • 93 POSTS
I have a short question; can you put the upper timing chain gasket on without removing valve cover if so how?
May 25, 2016 at 4:02 AM
DOCHAGERTY
  • 9,606 POSTS
No, you cannot do that. The valve cover comes off before that can be performed
May 25, 2016 at 10:37 AM
  • 55,711 POSTS
Thanks Dr. nice to see you on, cool cat! :)
May 25, 2016 at 10:55 AM
REARDRIVE
  • 93 POSTS
I just put new valve cover gasket on do I need to buy another set of valve cover gasket ? Thank you
May 25, 2016 at 5:44 PM
  • 31,937 POSTS
If it is a rubberized gasket and not glued you should be able to re use it after such a short time,, otherwise replace it to be safe.
May 25, 2016 at 8:38 PM
REARDRIVE
  • 93 POSTS
THANK YOU
May 25, 2016 at 9:10 PM
DOCHAGERTY
  • 9,606 POSTS
Agreed Thx Mark
May 26, 2016 at 8:33 AM
