Upper radiator hose leaking
300,000 MILES • V8 • 4WD • AUTOMATIC
MJTSEBE
  • 12 POSTS
How do i fix a leaking upper radiator hose?
May 14, 2020 at 11:52 PM
This depends on how and where it is leaking. If it is leaking from one of the ends then it could just be a hose clamp not being tight enough. However, if it is from the middle or the end of the hose is split then the hose needs to be replaced.
https://www.2carpros.com/articles/replace-radiator-hoses
Let us know if you have other questions. Maybe get a picture of the hose and the area of concern and we can give other ideas if needed. Thanks
May 15, 2020 at 12:36 AM
MJTSEBE
  • 12 POSTS
Hi KASEKENNY1,
Thank you for such a prompt response. as per my attached picture, the leak is coming from the end on the radiator side and not the engine side, unfortunately i am not able to locate the end of the clamp to tighten it up. it looks like the clamp there is not the normal adjustable one and is mounted on a plastic joint. I hope this provide enough clarity.
May 15, 2020 at 1:38 AM
I am sorry. The picture did not attach. Can you try it again so we can get on the same page? I am sure once seeing the clamp I will be able to help with some ideas. Thanks
May 15, 2020 at 11:38 AM
MJTSEBE
  • 12 POSTS
Thank you for the response. Please see attached picture, it looks like there is no clamp but just a silver ring around the hose and a plastic connector to the radiator.
May 17, 2020 at 8:27 PM
Thanks for the picture. That is not a clamp that you can tighten. That is a molded line that has what is called a tension clamp installed on it. I attached a picture of the replacement line and as you can see it comes with that already installed and the elbow is where you disconnect it. If this is leaking then you need to replace the whole hose. Unfortunately it is not one that you can tighten or you will crack the molded plastic and it will leak worse.
May 18, 2020 at 1:02 PM
MJTSEBE
  • 12 POSTS
Thank you, I really appreciate your prompt response and has been very helpful.
May 18, 2020 at 5:48 PM
MJTSEBE
  • 12 POSTS
KASEKENNY1,
I have another issue related to the same car, my dashboard control buttons are not working and that include my airbag light on the gear liver panel, hazard indicator button , rear head rest button and the central lock/unlock button, , i have checked all the fuses and they are all okay, unfortunately am struggling to locate the electronic fuse as is mentioned in the fuse chart. This only happened few days ago when i went to the filling station to fill up and check my water level, the attended pushed the hood very hard when closing it and thereafter i realized that the buttons have stopped working and my hazards cannot switch on when i press the hazard button.do you perhaps have any idea what might be the cause. Thank you in advance once again.
May 18, 2020 at 6:01 PM
RENEE L
  • 1,260 POSTS
My name is Renee and I am the site's editor. I noticed in your question you are now asking about a different issue with your vehicle. Can you please start a new question? The reason being; in order for the site to properly index the questions they need to about one issue/vehicle otherwise people will not be able to find the answer to this question under a different subject. The premise of our site is to assist those that need direct help and also provide a resource for others that have the same issue.
For your convenience here is the link:
Make sure you are logged into the site before clicking on the link.
Thank you and have a great rest of your day!
Renee
May 19, 2020 at 3:15 AM
MJTSEBE
  • 12 POSTS
Thanks Renee.
Noted.
May 19, 2020 at 6:35 PM
Yes. Renee is awesome. Thanks!
I think I posted on that new question earlier tonight. Let us know what you find on that one as well. Thanks.
May 20, 2020 at 12:21 PM
