Upper idler pulley
130,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PADUCAHJOEDADDY84
My upper idler pulley bearing froze up. When I removed it the nut was missing and the bolt threads were completely gone on one side due to friction. I ordered the pulley which came with the fixed bearing. I wrongfully assumed that it would have the bolt and nut with it. My question is how do I find a replacement bolt or the part number? I have tried Napa, Advance, AutoZone, O'Reillys and not one carried the part nor could tell me a part number.
Apr 25, 2017 at 3:43 AM
HMAC300
  • 48,601 POSTS
best thing here is to try to match other bolt if it is the same size. then go to auto parts and find a bolt/nut that will fit. auto parts won't know. you can go to hardware as well just get a hardened bolt which in metric is on the head of bolt the higher number the harder it is.10.9 would do for hardness. if you cannot get a nut you can heli coil it and kits are available at auto parts and hardware stores.
Apr 25, 2017 at 5:17 AM
PADUCAHJOEDADDY84
Thank you. Is there not a website to look up part numbers?
Apr 25, 2017 at 5:42 AM
HMAC300
  • 48,601 POSTS
yes a dealer and that is about it. really all you need is screw size a mechanic would do what I explained to do.
Apr 25, 2017 at 7:46 AM
