Upper control arm bushings installation?
200,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
FLOATR925
  • 163 POSTS
I've managed to get out the old bushings w a 3-jaw puller (I changed it to a 2 jaw see pic) then a big C clamp on 2nd one. I pressed in the new one with C clamp on one side but can't get 2nd one in with that middle bar. My tool is closed at the other end of c clamp. What technique can I use or tool to press in the 2nd one? That middle bar sure blocks a lot!
Mar 24, 2025 at 2:26 AM
FLOATR925
  • 163 POSTS
That's after pushing the rod hard with jaw puller it popped out. I put new one in with big C clamp rented for ball joint on 1 but can't get 2nd one seated due to bar. I got access to the AutoZone and O'Reilly tool rental also.
Mar 24, 2025 at 2:30 AM
STEVE W.
  • 15,420 POSTS
Normally I use a press with a bushing on it to press it in while supporting the arm right around the bushing. Lacking those you could put the arm in a vice with the bushing in the hole and use the vice as a support and then use a heavy hammer and a chunk of pipe to drive the bushing in. Or use this as an excuse to buy a press.
https://www.2carpros.com/articles/lower-control-arm-bushing-replacement
Mar 24, 2025 at 8:56 AM
FLOATR925
  • 163 POSTS
I can try a hammer and the sleeve around the bushing. Is there a technique I can try with the nut on bolt end, and a big metal washer or that cup in the kit -
And an Air Ratchet or will that just push the rubber?
Mar 24, 2025 at 10:17 AM
STEVE W.
  • 15,420 POSTS
You can't use the nut to pull it in as it will damage the rubber of the bushings. I use a press myself but there are folks who haven't got a press. The hammer method works but you need to support the arm to prevent damage.
Mar 24, 2025 at 3:01 PM
FLOATR925
  • 163 POSTS
Actually, I was able to get it on by renting both small and medium 3 or 2 jaw pullers an used the bigger grip teeth off little one on that big one and a hole saw worked great as the cup with a couple big flat washers.one side is a hair closer on that metal bushing but both sides of that 1 bushing is in ..I don't think it will factor ..Which way does that middle bar swing -.with the curve edge facing out or in? See last pic arrow.
Mar 25, 2025 at 6:54 AM
FLOATR925
  • 163 POSTS
I will feel the one on the other side. I think the curve faces in? can I get away with using a hydraulic ratchet to tighten all 4 Nuti. I know it's very high torque, but I plan to get an alignment. What's the ft lbs ?
Thanks
Mar 25, 2025 at 7:21 AM
FLOATR925
  • 163 POSTS
This is odd. But the other top control arm pivot bar in middle is straight across no curves. Is that normal? I'm assuming it is since the straight one I ordered won't fit passenger. So which way does that bar curve? Were these made like this with one side having curved bar?
Mar 25, 2025 at 7:33 AM
STEVE W.
  • 15,420 POSTS
The curve usually faces away from the spring but in this case service information doesn't say. The only thing I find is an image on the part section that shows the pivot turned 180 degrees from where you have it in the attached image.
Mar 25, 2025 at 2:31 PM
FLOATR925
  • 163 POSTS
One side where the holes have a rough tic tack toe edge I think it goes on top.
Mar 26, 2025 at 2:46 AM
STEVE W.
  • 15,420 POSTS
The serrated area should be the side that hits the mounts. They are what bites the steel to help hold them in the correct position after alignment. Sort of a crude lock washer. They unfortunately don't show that in service info though, this is all they show for both sides. However, the serrations go toward the mount not where the nut is seated.
Mar 26, 2025 at 10:54 AM
FLOATR925
  • 163 POSTS
Okay, I have it-serrated edges, facing down and is on, correct? From looking at videos. Do I need to tighten all 4 to torque after car is on the ground or should all 4 be torqued with no pressure? I think the sides are 130ft and middle are 155ft? I tightened it to torque before putting load. I plan on an alignment and didn't mark the middle bolts either.
Mar 26, 2025 at 11:51 AM
STEVE W.
  • 15,420 POSTS
Torque the mount bolts fully. They will need to loosen them to do the alignment, but you want them torqued for now. The bushing bolts for the arms and shocks are where you torque them on the ground. That way they are not under a constant twist, but flex as the suspension moves. Generally, for those I like to leave them loose enough that the bushing inside can move, then go to each corner and bounce that vehicle, then torque them.
Mar 26, 2025 at 12:12 PM
FLOATR925
  • 163 POSTS
Got the sides as tight as I could with it down.1 side is too close to the exhaust flange. Will going as tight as I can with a long pipe work . It's super tight w thread lock.
Will my first drive be odd as in shaking or drifting to the side as driving to get alignment? I put the pivot bar bolts in the center point.
Mar 27, 2025 at 6:28 AM
STEVE W.
  • 15,420 POSTS
Should be okay to tighten it that way. It shouldn't shake but wander, odd steering and tire squeal are possible as the alignment can be way out. on caster, camber and toe. If the drive is more than a mile or so I'd probably opt to flatbed it, just to save the tires and any possible problems.
Mar 27, 2025 at 8:41 AM
FLOATR925
  • 163 POSTS
It was kind of loose before because I replaced a lot with all tie rods and sway bar links. I will go on my BK road and test run it ...it's about 3 or 4 miles away. What causes a squeal noise?
Mar 27, 2025 at 12:52 PM
STEVE W.
  • 15,420 POSTS
It depends on how far out the alignment is, the tires can be pointing in multiple directions other than where they should and can scrub and wear fast if it's far enough out.
Mar 27, 2025 at 6:43 PM
