upper air filter hose
92,000 MILES • TURBO • MANUAL
ROBSC
The upper hose on my air filter box is blowing out air not sucking it into the engine. what is the cause of this? Thank you.
Jan 17, 2017 at 10:24 PM
HMAC300
  • 48,601 POSTS
check the duct work probably not on correctly or a clamp has broken or been taken off. See picture, not sure where you are talking about.
Jan 17, 2017 at 11:00 PM
ROBSC
It is the hose that comes out of the top of air filter box and I suppose allows filtered air into the motor. someone told me it is a sign of a timing issue? Is that possible? Thanks
Jan 18, 2017 at 12:35 AM
HMAC300
  • 48,601 POSTS
maybe if a backfire, but if a timing issue scan for codes auto parts does for free.
Jan 18, 2017 at 1:44 AM
