Upgrade my fuel pump for more power
2.5L • TURBO • 4WD • AUTOMATIC
BEN STEPHEN
I am considering upgrade to my ford ranger 2.5 turbo diesel engine and my friend ask me to service the fuel pump before any other things..Does this mean upgrading my fuel pump to heavy duty setting..thanks 2carpros
Mar 7, 2015 at 7:03 PM
  • 31,937 POSTS
The injection pump will not require servicing, any work on the pump will require a pump test bench to re calibrate all settings, you only need to replace any filters in the system.
Mar 7, 2015 at 9:07 PM
BEN STEPHEN
thanks you sir for the reply, but can you show my any pictures or which filters do you mean sir..thanks in advance
Mar 9, 2015 at 10:28 AM
  • 31,937 POSTS
There will be a canister type fuel filter under the bonnet, at is all you have to worry about,
Mar 10, 2015 at 11:39 AM
