I failed at educating myself. Two similar cars swapped compressors due to running car locking up. The system was open for 30-45 minutes. Previously running cool, not cold, but adding 134 every few weeks.
Swapped compressor ran great for 4 days after only can recharge, no vacuum on system, then just stopped. Car thinks it's running by RPMs still raising, don't think fan is running at same time, but was while running.
Fixing to get gauge and pump set recommended, and compressor/drier kit from Rock Auto.
Was wondering, new compressor will be loaded with 3oz oil and additional 8oz. If I were to just try and vacuum a system only replacing the accumulator/drier filter to check if old compressor still works, what to look out for or recommendation on trying to test fire the old compressor, maybe even with system open to make sure it's not locked up. Also, does vacuuming a system remove the refrigerant oil if the compressor is at bottom of motor and not removed?
Thank you
Thank you
Jun 15, 2022 at 10:14 AM
