Key fob not working properly
321,000 MILES • 7.3L • V8 • TURBO • 4WD • AUTOMATIC
ALYFILM1
The fob works but nothing happens. Doors don't unlock, lights don't flash, horn doesn't sound.
Nov 21, 2019 at 2:12 AM
  • 110,251 POSTS
The first thing I suggest is to try reprogramming the system. Here are the directions:
REMOTE TRANSMITTER PROGRAMMING
NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
Programming (or reprogramming) the keyless entry remote transmitters into the generic electronic module (GEM), Perform the following steps.
1.Turn the ignition from OFF to RUN 8 times within 10 seconds, ending in RUN. If the vehicle security module has successfully entered the program mode, it will lock and unlock all the doors.
2. Press any button on a keyless entry remote transmitter, and the doors will lock then unlock to confirm that each keyless entry remote transmitter has been programmed.
3. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
4. Turn the ignition switch to the OFF position, or wait up to five minutes after Step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will unlock all the doors one last time.
______________________________________
Let me know if that helps.
Nov 21, 2019 at 10:56 AM
ALYFILM1
Worked like a charm. Thank you for your help!!
Nov 21, 2019 at 11:17 PM
  • 110,251 POSTS
Excellent. You are very welcome and I'm glad it helped. Let us know if you need help in the future.
Have a good weekend.
Nov 22, 2019 at 1:26 PM
