unknown noise with slight load on engine
1995 FORD THUNDERBIRD
88,000 MILES
N2UBP
1995 Thunderbird LX with 4.6 V8, automatic, ABS, 4 wheel disk brakes, 88,000 miles, no rust, original owner, garaged, not parked out on street, regular maintenance performed on timely basis, mobil 1 oil since day 1 of ownership, no burnt trans or PS fluids, check engine light off, no codes in the scanner. Trying to figure out / find the source of a noise that only appears when driving with a slight load on the engine, goes away when light load or heavy load. Almost sounds like engine ping or catalytic converter heat shields rattling.. No change in tach RPM when rattling happens, no loss of power. No change if traction control is turned off. Only other problem I am seeing is low alternator voltage according to cluster gauge with A/C on or headlights and heat on at idle, battery is 6 months old. Hoping this isn't a water pump or timing chain tensioner issue or some unknown auto transmission issue. Suggestions appreciated. - Steve
Sep 6, 2013 at 5:09 AM
CARADIODOC
  • 34,381 POSTS
There is a tool you might be able to borrow or rent from an auto parts store that borrows them called the "Chassis Ear". It is a set of six microphones, a switch box, and headphones. You clip the microphones to suspect points, then drive around while listening with the headphones. You can move the microphones around to zero in on the source of the noise. Be aware that many mechanics have never seen or even heard of this tool. Suspension and alignment mechanics use it to find rattles, squeaks, and other noises.
Sep 6, 2013 at 5:38 AM
