No crank no spark, nothing is turning on, my fuel pumps not turning on?
898,905 MILES • 6.6L • V8 • AUTOMATIC
DUSTI84
I drove my motor home to a gas station, and I turned the engine off, when I went to turn the engine back on nothing happened; no crank, no spark, nothing's turning on, and my fuel pumps not turning on. The battery is brand new. I thought it was that I needed a new ignition switch and an ignition lock cylinder, so I bought one and installed it, still no power. What could cause my engine to refuse to start and no spark or do anything with no noise at all? When I shut it off and then less than an hour later, I turn it back on or I go to turn it back on and it won't do anything. I have been stranded for two days now with no help.
Oct 15, 2022 at 9:52 PM
  • 55,740 POSTS
This happens when the positive battery cable needs to be replaced. Also, check the fusible links down at the starter, they should be like a solid wire. Also, cleaning the battery cable connection may help as well. Please check out this guide to help you with the repair:
Please go over this guide and report back.
Oct 16, 2022 at 6:11 AM
