Unknown driver message and will not start
205,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
HD2424
  • 190 POSTS
In my truck has unknown driver and won’t start. The key lock cylinder was faulty, and I changed that. I held the positive and negative battery terminals together for 30 seconds went in truck and driver 1 was on information screen. Turned truck off and 45 minutes later it went back to unknown driver. My next step was I changed ignition switch because I didn’t know if key cylinder messed it up. Again, held positive and negative battery together for 30 seconds got in truck had driver 1 but would not start but I assume I need to do key relearn. I waited a hour turned on key and it was back to unknown driver. In addition, when I turnkey off the information screen sometimes has letters and numbers that make no sense. Also, I have a battery shut off switch have used it for years and never a problem. My key fob stopped working long time ago but truck always started and ran good. I also hooked a wire on pin 87 and touched battery and truck turned over but would not start.
Oct 25, 2021 at 12:52 PM
  • 110,251 POSTS
If you turn the key on to the run position and let it set for approximately 10 minutes, does the anti-theft turn off? If so, will it then start?
Also, I did some research on this indicator. I was able to find a technical service bulletin related to it. Take a look at the attachments below and let me know if they help.
Oct 25, 2021 at 1:44 PM
HD2424
  • 190 POSTS
Okay, I’ll try that and let you know.
Oct 25, 2021 at 4:39 PM
HD2424
  • 190 POSTS
I checked all fuses the only thing was some trailer lights, and my head lights fuse it’s been like that a long time. But I was finally able to pull a code p1518. What do you think? Could it be tac module or BCM?
Thanks
Oct 25, 2021 at 10:37 PM
HD2424
  • 190 POSTS
Also, it sometimes goes to driver 1 then 2 unknown driver.
Oct 26, 2021 at 12:49 AM
  • 110,251 POSTS
The TAC could be bad, there could be a wiring/power issue, or even a serial data bus issue.
Take a look through the attached diagnostics. See if you are comfortable performing them.
Let me know,
Oct 26, 2021 at 10:32 AM
EARL JACKSON
I took my vehicle to the Chevrolet dealership. They said bad ignition switch. Had to order new ignition switch and ordered to new keys. Had to order a brand-new cluster panel. Ignition switch and two keys $678.00. Brand new cluster panel $876.00. $1,400.00 with labor.
Aug 3, 2022 at 7:29 AM
HD2424
  • 190 POSTS
Thanks, I’ll try that.
Aug 3, 2022 at 7:38 AM
