Unidentified part on engine block
300,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
LOGANWILCOX
  • 7 POSTS
There is a bolt that had a wire attached into it the wire is broken off, I'm trying to replace it but I need help identifying the part.
May 16, 2022 at 2:34 AM
SQM
  • 6,383 POSTS
It could be a ground for the engine harness.
What part of the engine is it located?
Do you have any components that are not functional?
If you would please upload a few pictures of the bolt and the location, this can help with determining what it might be.
May 16, 2022 at 9:16 AM
LOGANWILCOX
  • 7 POSTS
Yes, I can add a few pictures.
The engine is overheating
It’s on the left side of the engine block.
May 16, 2022 at 9:33 AM
