Uneven idle
147,000 MILES • 4.3L • V8 • 2WD • AUTOMATIC
QMCSDUGAN
It lopes, the engine light flickers as it lopes. Once I get going it smooths out and runs well. Just replaced all the spark plugs. All were picture perfect.
Oct 1, 2018 at 7:17 AM
Good evening.
It sounds like the idle circuit of the carburetor is not working correctly.
Did you try adjusting the carburetor idle air screws?
Can you upload a picture of the carburetor with the air filter removed?
Oct 1, 2018 at 8:09 AM
QMCSDUGAN
I will try to get the picture to you. Last night after getting home I took a video with I hope good enough to sound. I do not know if I can upload that, as I said, if it is good enough. Rats! It is not letting me access the video file. I will have to do it again tonight, and add per this site's parameters.
Oct 2, 2018 at 3:01 AM
Sounds like a plan.
Oct 2, 2018 at 3:04 AM
QMCSDUGAN
It did no upload got home late and now back at work. I will try to figure it out later.
Oct 3, 2018 at 1:17 AM
Okay, sounds good. Will be here.
Oct 3, 2018 at 1:19 AM
