Unable to get the key out of ignition
300,000 MILES • 1.5L • 4 CYL • TURBO • 2WD • MANUAL
PUNITH KUMAR K M
Key is jammed in the ignition and the steering wheel is locked. i am not able to remove key nor able to steer the vehicle after turning the car on.
Feb 25, 2018 at 5:59 PM
STEVE W.
  • 15,394 POSTS
So the engine will start but the steering stays locked and the key will not come out. That sounds like the steering lock actuator bar has snapped inside the column. I do not have a breakdown of that particular steering column but most use cheap metal for that part then seem shocked when they fail. The easiest way to repair it would probably be to replace the entire steering column and have a locksmith re-key the "new" column to use the current key. That way you do not need to carry multiple keys and possibly damage a lock if you used the wrong key.
The other option would be to take the steering column apart and replace or just remove the broken parts. The factory book I found online does not show how the column comes apart. Just how to remove it.
Feb 26, 2018 at 3:47 AM
