ANTIFREEZE is running low?
275,550 MILES • 0.9L • 6 CYL • 4WD • AUTOMATIC
MAMMADOV
ANTIFREEZE is running low The battery is new but it runs out often The sound of the radio monitor sometimes cuts out completely when the starter is pressed, sometimes it works?
Dec 27, 2025 at 3:58 AM
  • 55,859 POSTS
So this sounds like three problems and we only handle one per thread so please start new questions for the radio and starter issue. For the coolant leak I would use a pressure tester, here are to guides to help us see what the problem is so we can fix it. PS, they did not make the LEXUS RX 300 in 1982?
https://www.2carpros.com/articles/radiator-pressure-test
and
https://www.2carpros.com/articles/car-is-leaking-coolant
Please go over these guides and get back to us.
Dec 29, 2025 at 4:30 AM
