Replaced U-joint now the other U-joint is not centered
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
TAZZDAREAPER
I removed the drive shaft and replaced one U-joint. when I went to replace the other U-joint I was able to remove one of the U-joint caps. Once I removed the one U-joint cap the other side cap became off-centered and I have been unable to center it properly to press it and remove it. I have used a rubber mallet to try and align it but It did not work. I then tried to use a flat head and tried to align It that way and it did not work just made it worse. How do I recenter the cap so I can replace it properly?
Aug 30, 2018 at 7:53 PM
  • 110,248 POSTS
Under the cap are many needle bearings. Are you sure one did not slip down in and is causing the cap to not align? It can happen easily. I was able to find a good picture of one online, so I attached it so you can see what it looks like on the inside.
Let me know if this helps.
Aug 31, 2018 at 11:17 AM
