Two DTCs simultaneously
153,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
IMP
P2106 TAC "Forced Limited Power" and B1342 "ABS Module Malfunction". All resources claim P2106 relates only to Throttle Control System malfunction.
Question: Is P2106 added as a safety measure when ABS fails? Have replaced Throttle Body Assembly complete, new, and PCM reconditioned, flashed to OEM specs. No change to DTCs.
Jun 13, 2016 at 10:48 AM
  • 55,781 POSTS
Hi, we have seen this problem before, the problem is with the transmission please check the fluid level or have it serviced. There is no dip stick so a shop will need to do it, see if it is leaking though to see if we are on the right track. Let me know what you find
Best, Ken
Jun 15, 2016 at 1:35 PM
