Twin catalytic converters replacement
129,000 MILES • 2.9L • 6 CYL • 2WD • AUTOMATIC
ENGINEERINGDAD
  • 35 POSTS
On my vehicle listed above T6 (twin turbo), what would be the best procedures for me to replace both manifold mounted catalytic converters?
(1) Remove the entire hood?
(2) Cut a piece of plywood to the exact inner areas of fender well (where the hood countersinks/rest) and then lay across engine (facing windshield), working downward with hand tools?
(3) What is the difficult level of completing successfully? Keep in mind I am a Master Mechanical Engineer in the commercial industries, I do not give up easily.
Does anyone have a step by step?
Jul 18, 2018 at 9:47 PM
Good morning.
This is best done with a lift as access is better from the bottom.
The procedure below as well as pictures.
Book time is 2.5 hours.
Three-way catalytic converter (TWC), replacing
Special tools:
999 5543 SOCKET NV-22 HO2S See: Vehicle > Electrical / Mechanical Repair > 999 5543 Socket NV-22 HO2S
999 5972 FIXTURE See: Vehicle > Electrical / Mechanical Repair > 999 5972 Fixture
Note! As the illustrations in this service information are used for different model years and / or models, some variation may occur. However, the essential information in the illustrations is always correct.
Preparation
imageZoom/Print
Remove the splash guard from under the engine.
Remove:
- the connectors for the heated oxygen sensors (HO2S)
- the wiring for the heated oxygen sensors (HO2S) from the mountings
- the screw for the mounting for the engine stabilizer brace on the engine
- the engine stabilizer brace between the suspension turrets
- the plastic charge air pipe. Place to one side
- the plastic intake pipe. Put it to one side.
Removing components
imageZoom/Print
Remove:
- the intake and charge air pipes from turbocharger (TC)
- the heat deflector plates
- the upper heated oxygen sensors (HO2S)
- the expansion tank cap.
Removing three-way catalytic converters (TWC) / front exhaust pipe
imageZoom/Print
Remove:
- the nuts. Disconnect the front exhaust pipe from the turbocharger (TC)
- the nuts where the exhaust pipe divides downstream of the three-way catalytic converter (TWC)
- the center SIPS member.
Disconnect the brake pipe from the clips on the front SIPS member.
Remove the screws from the front SIPS member.
Slide the three-way catalytic converter (TWC) (with the heat deflector plate) back and then lower it.
Note! For tightening torques, see: Tightening torque See: Engine > Mechanical > Tightening Torque.
Note! To ensure that there is no exhaust leakage, see: Flanged joint, assembling See: Exhaust Pipe > Removal and Replacement > Flanged Joint, Assembling.
Transferring components
imageZoom/Print
Transfer:
- the SIPS member with the exhaust system mountings
- heated oxygen sensors (HO2S).
Lubricate the heated oxygen sensors (HO2S). Tighten the heated oxygen sensors (HO2S). See: Tightening torque See: Engine > Mechanical > Tightening Torque. Use tool 999 5543 SOCKET NV-22 HO2S See: Vehicle > Electrical / Mechanical Repair > 999 5543 Socket NV-22 HO2S.
Jul 18, 2018 at 10:47 PM
ENGINEERINGDAD
  • 35 POSTS
OBD2 scanner code reader images.
Jul 19, 2018 at 1:54 AM
Okay, when the downstream O2 voltage is the same as the upstream voltage, that is when the catalytic converters are not doing their job anymore and need to be replaced.
Those readings indicate a bad catalytic converter.
Jul 19, 2018 at 3:33 AM
ENGINEERINGDAD
  • 35 POSTS
Thanks Roy.
Jul 19, 2018 at 9:47 AM
You are welcome.
Jul 19, 2018 at 9:49 AM
