I need an under hood wire schematic
With ECM Pin out on all three ECM plugs
Also needs to cover Fuel Injector connectors
And Ignition coil connector
All with Pin number and wire color
Possibly circuit number?
No 12V to the Ignition coil
No communication with scan tool but the DLC does have power and ground (can not get data stream to check for RPM signal from the CPS)
No fuel injection pulse (checked with noid light)
Engine crank speed sounds normal
I suspect either a fairly bad wire harness issue or an inop ECM
Sep 25, 2015 at 10:01 AM
