turns over no start no compression
153,855 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
HUTCH3902
  • 7 POSTS
Car turns over want start sounds like has no compression don't see any signs of water in oil and timing belt is ok it died started back then after parker lost compression
Feb 8, 2014 at 1:06 PM
  • 75,988 POSTS
Check engine compression if okay-check if the timing belt is aligned properly meaning the camshaft/s and the crankshaft at top dead center-
Feb 8, 2014 at 3:06 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
watch the timing belt to make sure it spins when you crank the engine. it could have spun the cogs off the belt at the crankshaft. if it spins then take out the spark plugs and check each cylinder for puffs of air as its cranked. if none then compression is lost due to valvetrain/camshaft damage
Feb 9, 2014 at 7:50 AM
