Welcome to 2CarPros.
Most likely the problem is either fuel related or ignition spark related. With that in mind, we need to check if there is proper fuel pressure to the engine and if the spark plugs are getting spark. Take a look through this link:
Here are links that explain how to check fuel pump pressure and ignition spark:
____________________________
Now to check the fuel pressure, you will need a gauge. Most parts stores will lend / rent the gauge to you. When checking the ignition spark, the use of some very basic electrical circuit testing equipment is needed. Here are links if you need to see how they are used:
Once you do these tests, let me know what is found and I can further advise you.
Take care and I'll watch for your reply.
Jul 4, 2019 at 11:46 AM
