Turns over but will not start
130,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
CHRISTOPHER LEE SIMPSON
Car turns over but will not start when cold out (2003 Lincoln town car).
Jan 20, 2021 at 1:24 AM
  • 110,251 POSTS
Chris,
Will it start using starting fluid regardless of temperature? If so, either we have a weak fuel pump or there is an issue with the engine coolant temperature sensor.
Do me a favor. Let me know if you have access to a live data scan tool. If you do, compare the ECT signal to the actual temperature. If it is okay, then check fuel pressure. Here is a link you may find helpful:
Jan 20, 2021 at 12:43 PM
