Engine turns over but will not start?
70,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ROBERT WRIGHT 8322
  • 14 POSTS
it has fuel but no spark, I have replaced distributor cap rotor button and ignition coil. it's getting 12 volts to coil. But no sparks coming out of it.
Dec 8, 2019 at 7:22 AM
  • 110,251 POSTS
Have you checked the ignition control module? If it is bad, you won't get spark to the plugs. It is in the distributor. I attached a pic of it and the pickup coil in the distributor. However, my first suspect is the module. It is number 14 in the picture. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Please run down this guide and report back. Check out the diagrams (Below). Please let us know what happens. Joe
Sep 3, 2020 at 2:23 AM
ROBERT WRIGHT 8322
  • 14 POSTS
I have replaced the pick up coil but not the module. I'll try replacing it tomorrow. And let you know. Thank you for your advice.
ROBERT WRIGHT 8322
  • 14 POSTS
I replaced the module and it's running great. Thank you so much for your help.
  • 110,251 POSTS
Happy to help. I'm glad to hear you got it running. Take care and let us know if you have questions in the future.
ROBERT WRIGHT 8322
  • 14 POSTS
I have a question about the same truck. last night my son was driving it, and it backfired and just stopped. it will turn over and kind of run, its still getting gas.
  • 110,251 POSTS
Can I ask a favor? Someone will be happy to help; however, I need you to start a new thread. Your issues sounds a bit different and we like to keep the topic specific to one thing.
Thanks,
