It will turn over like it is going to start, but does not?
180,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JEANSIMMONS993
  • 14 POSTS
It will turn over like it is going to start, but does not. Three days ago I pulled out my driveway put it it in drive pushed gas petrol and acted as if I ran out of gas and shut off. Hasn't started since. I have checked spark plugs, changed coil, ignition control module, crank sensor, checked voltage. Still not starting. Tested distributor, and button. Please help
Aug 9, 2019 at 12:35 PM
94 TRANSAM
  • 680 POSTS
Hi, I am sorry you are having issues. Lets see if I can help you.
It can be difficult to figure out whats wrong when a car just shuts off. so lets start at the basics. An internal combustion engine needs 4 things to start and run. If it wont one of these 4 is missing.
1: Air_ Make sure your air filter doesn't have a rats nest in it and can pass air freely.
2: Fuel_ Check your fuel pressure. If it is low it could be a filter or a failing pump or even a crushed line. Here is a link to test that:
3: Spark_ It sounds like you went through most of the spark components but you didn't say you had it. Here is a link to test for spark:
4: Compression: https://www.2carpros.com/articles/how-to-test-engine-compression
Give these a go and you should find your issue. Either way let us know how things are going fixed or not. Hope this helps you out! Rich
Jun 5, 2021 at 7:48 AM
JEANSIMMONS993
  • 14 POSTS
I have done everything you said. Still nothing. No spark no start. Replaced ICM, distributor cap button mass Air flow spark plugs wires.tested everything.
  • 55,746 POSTS
The ICM and PCM work together you might have a bad PCM. Here is a guide so you can check the wiring with the engine wiring diagrams below:
JEANSIMMONS993
  • 14 POSTS
the pink wire is showing continuity to the ground from the PCM.
