Engine cranks but does not start
200,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
RAYRAY41472
Replaced coil pack, car was running for about 5-10 minutes then it shut off as if it was out of gas. Added 5 gallons of gas, now it just spins and spins and spins still will not start, just turns over. I was also wondering where the fuel pump shut off switch would be located. I know nothing about this kind of vehicle so please answer in step by step details. Thanks
Jan 25, 2021 at 2:17 PM
  • 110,248 POSTS
Did you lose spark to the plugs or fuel pressure? That is the first thing we need to identify. As far as a fuel reset, this doesn't have one.
Do this. See if it starts for a couple of seconds and then stalls if you use starting fluid. If it starts and then stalls, we know it is a fuel related issue. If it still does nothing, it's likely an ignition issue.
Here are a few links you may find of interest or helpful:
Let me know what you find. Also, let me know if the no start was an issue before you replaced the coil.
Jan 26, 2021 at 6:21 AM
