turns over but no start
100,000,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
MEMIKEMODESTO
my car turns over but no start. but oddly enough i noticed that the check engine light and the oil light does not flash when turning the key to the on position no A/C no blower, no electric windows, but the head lights and the running and brake lights work. i have tried changing the relays fuses coil packs i have sprayed starting fluid into the throttle body nothing i ran a obd 2 on it it came back with no stored or pending codes. so now i about to change the computer. what do you think?
May 18, 2017 at 10:55 PM
HMAC300
  • 48,601 POSTS
if it has theft deterent then that may be your problem shutting ignition/fuel off. see if it has the module on right side of dash then try another key or resetting anti theft.
See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
this year may be different from our article however.
Feb 25, 2021 at 7:59 AM
