engine no start
210,000 MILES • 6 CYL • 2WD
DANAFITZMO69
The other day my car would not start. It kept turning over but would never start. Before my ex boy friend and I took anything out to test it we checked the fuse and it did end up just being the fuse. We put a different fuse in that I was not using (just temperature) and when I put it in the car started right up. Now three days later I went back to try to start the car and nothing. Doing the same thing but this time I checked the fuse. It is not busted. I put the fuse in a different spot just to be sure and it was not the fuse. I also tried to put a different fuse in and still nothing. Please help!
May 2, 2017 at 2:02 AM
  • 55,748 POSTS
We need to see if the engine has spark when it wont start, these cars had a big problem with the ignition distributor which caused intermittent not starting.
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
Sep 28, 2020 at 10:13 AM
