engine no start
125,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
LOUIS GEVAS
turns over easy, has good spark, good fuel pressure and good compression. it is TDC rotor cap. all new spark to all plugs good. still no start.
Apr 4, 2018 at 6:10 PM
  • 55,748 POSTS
It sounds like the injectors or not opening. Does it run if you spray starting fluid? Here is a guide to help you confirm injector pulse:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Please let us know what you find.
Cheers, Ken
Apr 6, 2018 at 4:36 AM
LOUIS GEVAS
the fuel injector are fine and working still no start. could it be the CPC? what else could it be? please let me know. thank you
Apr 6, 2018 at 8:49 AM
  • 55,748 POSTS
Yes it could be the CPS. Here is a guide to help you see what you are in for changing the sensor out:
Cheers, Ken
Apr 7, 2018 at 5:04 AM
LOUIS GEVAS
it runs fine now thank you very much. it was the injector the fuel pump cut off switch. fun for every one! it runs fine now. thanks for your input help. i will be using this site again.
Apr 7, 2018 at 5:51 AM
  • 55,748 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Apr 9, 2018 at 2:09 AM
