The engine turns over but does not start?
150,000 MILES • 4.6L • V8 • TURBO • 4WD • MANUAL
BOBBYAND
Doesn't run.
Jan 2, 2024 at 11:29 AM
  • 110,251 POSTS
In most cases, a crank no-start condition is caused by either a loss of fuel or an ignition spark. If the starter motor is turning the engine, here is what I need you to do:
See if the engine starts with starting fluid. If it does and then stalls, we will know its fuel related. If there is no change, I need you to check for spark to the spark plugs.
Here is a link that explains how to check for spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know what you find.
Jan 2, 2024 at 11:45 AM
