My truck turns over but will not start
230,567 MILES • 4 CYL
ACOOLTONYT
My truck turns over but will not start. I replaced fuel pump,crank sensor, fuel filter, fuel pump relay and even throttle body, but will not start. fuel rail is getting fuel but will not start. I put starting fluid in it and it runs for bout forty seconds. any suggestions?
Nov 14, 2017 at 6:36 AM
  • 110,248 POSTS
Check to make sure the fuel injectors are getting power. If it runs on starting fluid, it's a fuel related issue. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Nov 14, 2017 at 11:50 AM
