Engine cranks but does not start?
210,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
RINGLEBACK
It turns over but will not start. It is getting fuel but is not getting any spark.
Mar 28, 2023 at 4:09 PM
  • 55,746 POSTS
When you try to start the car does it have a security light flashing? If not, you can use a scanner to see if the crankshaft sensor is picking up a signal, if not I would try replacing the crankshaft angle sensor. Here is a guide that can help, and I have included the crankshaft angle sensor location in the images below.
https://www.2carpros.com/articles/car-not-running-advanced
This guide shows how to use a scanner. You can get a CAN scanner (Controller Area Network) from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Mar 30, 2023 at 2:54 AM
