Turning over but stalls out please help
179,568 MILES • 2.2L • 4 CYL • MANUAL
SUSIE ALEXANDER
Was running great. Had to disconnect battery and replace headlight bulb. Now radio will not work and it will turn over but stalls out. Please help me.
May 6, 2017 at 10:39 PM
HMAC300
  • 48,601 POSTS
you may need a code to get the radio to work if it lights up and asks for a code try last four digits of VIN number or if you have a manual it may be in there or you will have to call Honda on their 800 number see if they have it. If you have a security system try a reset on it to start and also check fuel pressure with a gauge as that is problem a lot of times. See links.
https://www.2carpros.com/articles/how-to-reset-a-security-system
May 7, 2017 at 1:08 AM
