How to turn off System Message Indicator Light?
167,000 MILES
OZZIE59
I want to turn off or have it turned off System Message Indicator Light ( i ). Is there any way I can do that? Thank you.
Oct 20, 2022 at 5:04 AM
  • 55,851 POSTS
The system Message Indicator Light means there is a code in the computer systems CAN of the car (controller area network) this could be the HVAC, ABS, Traction control, SRS. systems. You can retrieve the codes and then clear them using a CAN scanner which has become pretty easy. You can get a CAN scanner (Controller Area Network) from Amazon for about $36.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Amazon CAN scanner link for about $35.00.
https://amzn.to/3R9lJ60
Oct 21, 2022 at 2:57 AM
