Turn the key to accessories and nothing works. Is it a fuse? I would like to listen to my radio wit out the car being cranked.
Jul 11, 2017 at 10:19 AM
CARADIODOC
✓Experienced Mechanic
More than likely the ignition switch is out-of-adjustment. It is mounted on the upper right side of the steering column, under the dash. There are two screws to loosen, usually 5/16" hex heads, then the holes are slotted to allow the switch to be slid up and down to adjust it.
Jul 11, 2017 at 3:40 PM
ROMEO257
MEMBER
1 POST
I have the same issue shuts off the ignition turn forward or back cause I would like to play my radio without cranking up. help
Nov 2, 2019 at 9:45 PM
It may be best to start a new post with your specific vehicle and issue because this was from a few years ago. However, assuming your vehicle is the same as this post, here is the process for replacing the ignition switch.
