Turn the key no click and no crank radio don't work?
130,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
TATMAN1972
Went to get into start the vehicle and everything worked all the way up until I turn the key and there was like a pop sound. The radio don't have sound and when you go to turn the key there is no sound no crank. The battery isn't weak, I did check for headlights and those are bright. Hopefully it's just a fuse issue, if you can please help me ASAP
Nov 10, 2025 at 12:41 PM
  • 55,542 POSTS
Yep, it does sounds like it can be a fuse so we should check these first, with the key on use this guide to help, check the fuses in the fuse panel under the hood as well as inside the car.
It can be the ignition switch but lets check the fuses first, also this video can help us see what's going on,
https://www.youtube.com/watch?v=6YRW8fyNudY&t
Please go over these guides and get back to us and upload a short video in your response of the problem, so I can see what's going on :)
Nov 11, 2025 at 2:55 AM
