Turn the key and nothing happens
180,000 MILES
KENTMAHONEY7
  • 6 POSTS
This is an SL2 model. Turn the key and absolutely nothing happens. The dash lights stay on. The headlights do not dim. Tried to jump the car and the results are the same. The heater fan does stop when the key is turned to the start position. I jump the contact points on the solenoid and it activates.
Aug 24, 2013 at 3:14 AM
SATURNTECH9
  • 30,868 POSTS
Sounds like a bad starter do you have a test. Light to do some testing ?
Aug 24, 2013 at 3:58 AM
KENTMAHONEY7
  • 6 POSTS
Replaced the starter thinking that was the problem. Nothing changed. Same results.
Aug 24, 2013 at 8:16 AM
SATURNTECH9
  • 30,868 POSTS
Do you have A test light to do some testing?Do you have a Automatic or manual transmission? Have you checked all the fuses inside fuses And fuses in the engine compartment?
Aug 24, 2013 at 3:49 PM
KENTMAHONEY7
  • 6 POSTS
Auto transmission. All of the fuses are ok. Will pick up a light tester if that will help.
Aug 25, 2013 at 12:11 AM
SATURNTECH9
  • 30,868 POSTS
Were going to need a test. Light to trace power when you get one here's what I want you to do first.Under the hood bellow the master cylinder. You will see the selector switch attached to the transmission it will also have the shift cable attached to it.You will see two big purple wires going to it.With the car in park and everything hooked up.Turn the key to the start position you should have power to both those purple wires.Let me know what you find.
Aug 25, 2013 at 12:52 AM
KENTMAHONEY7
  • 6 POSTS
Will be next weekend before I can test. Car with son at college 2 hrs away.
Aug 25, 2013 at 11:30 AM
SATURNTECH9
  • 30,868 POSTS
Alright keep me posted
Aug 25, 2013 at 12:34 PM
