turn signal stop when pressing brake and the right turn signal turns on the left signal i have no right turn signal.
Jun 16, 2021 at 9:37 PM
✓Experienced Mechanic
This happens when the bulb or socket for the blinkers either on the front here rear has melted and is allowing the contacted to touch please remove the rears first and inspect. here are guides to help you fix it:
