Front and back signals and hazard lights not working. checked fuses, bulb, both good.. replaced flasher relay.. still not working.
Oct 29, 2019 at 1:51 PM
✓Experienced Mechanic
Welcome to 2CarPros.
There is a change it is the multi function switch on the steering column. If you look at the attached pic, you'll see that both the flashers and signals are powered through that switch. However, I need to know something. Do the light turn on and not flash or is there nothing?
Image (Click to enlarge)
Oct 30, 2019 at 11:59 AM
BECKYMUNN
MEMBER
Inside/outside- left turn comes on steady light..not flashing.
Right side does nothing.
Hazards inside come on steady. not flashing.
Wipers work, high beams work.
Oct 31, 2019 at 4:30 AM
Welcome back:
You indicate the flashers stay on steady. Do both sides of the exterior light come on? If not and only one side, I suspect the switch has failed. I have a flow chart if you want to check the multi function switch operation. It is somewhat involved, but I'm happy to provide it if you feel it will help.
