Turn signals and hazard lights do not work
98,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
COBRA346
The fuse to the signals appears to be good. I could not locate the flasher relay under the dash or hood. Please assist.
Oct 11, 2019 at 2:48 AM
SCGRANTURISMO
  • 4,897 POSTS
There is no relay flasher in your vehicle. Instead it is controlled by the drivers MICU. he MICU is located in the under dash fuse panel and is probably failing. The MICU also controls all lighting, neutral safety switch, wipers, windows, locks, and security. I have testing instructions for the MICU/F Can network but it requires Honda's scan tool called the HDS to do them. If you would like I can send them to you. Please let us know I will shoot them right to you.
Thanks,
Alex
2CarPros
Oct 11, 2019 at 5:32 AM
COBRA346
Thanks. I took my car to a local shop and the tech said my multi function switch was bad. Does it coincide with the MICU?
Oct 11, 2019 at 5:58 AM
COBRA346
I don’t have a Honda scan tool. It there an alternative?
Oct 11, 2019 at 9:46 AM
SCGRANTURISMO
  • 4,897 POSTS
Yes it does. In the earlier reply I sent along a wiring diagram of the MICU. If you follow it to the bottom of the diagram you can see the combination switch. The hazard switch is on another circuit, but we are unable to see the internal circuitry of the MICU, but I'm sure that they share a circuit in the MICU. Please keep us informed as to how everything turns out.
Thanks,
Alex
2CarPros
Oct 11, 2019 at 10:57 AM
COBRA346
Thanks will do.
Oct 11, 2019 at 11:27 AM
